I mean as your bolting the ds up to the transmission there are 3 bolts that hold it to the trans right? but there are 6 holes on the dsbiggie wrote:I am confused as well. Diff to axles is 6 bolts, DS to Diff is 4 bolts.
I was thinking the same thing, there is just a spline on the transmission side, unless hes talking about the coupler on the two piece ds.breadbox wrote:no bolts hold the Driveshaft to the trans. Are you sure you are working on a 240sx?
http://s525.photobucket.com/albums/cc33 ... r/2402010/Warped161 wrote:I was thinking the same thing, there is just a spline on the transmission side, unless hes talking about the coupler on the two piece ds.breadbox wrote:no bolts hold the Driveshaft to the trans. Are you sure you are working on a 240sx?
you still didn't answer my question, even if i bolt it up like you say there will still be 3 extra holes, that's how i got the ds and transE7-S14 wrote:You or somebody else did this wrong.
No need to disassemble the DS, which is what you did. the piece in the transmission that's SUPPOSED to be a part of the DS, slides right out.
bolt it back together and pull it out as one piece.
its hard explaining this because this is common knowledge. DS are not Taken apart to be taken out or put in.
Have you worked on a car before?
