manual doors to SE doors. what can I do?
RedRum240
Car: 1990 240sx Fastback
I have a base model and I want to install some power door locks/windows. I was wondering If I got the door panels off a SE model what all woul di need to do the conversion? and also has anybody here had experience with those things you can buy to convert your car to power windows?
Juujai
basically itll be easier to take a pair of automatic doors and swap its all there you just gotta plug
RedRum240
where would I plug the wires into? for the manual doors? what cords will I need to solder into what fuses?
Silvia2b
Car: 95 240sx se / 07 G35s cpe / 2009 G37s sedan (rear-ended R.I.P.) / 19 Q50 rs400AWD
locks are an easy addition, you can buy the aftermarket actuator to move the lock assembly, usually like $15. the power window kits can be purchase as well. If you are willing to purchase the stuff aftermarket unless you already have the doors from a donor car. check out this site. http://www.autoloc.com/detail.lasso?itemid=PW4400
RedRum240
Hey bro thanks for the autoloc link... how good do you think those manual ones are? and if I buy the power locks from autoloc and the windows. for the full power conversion... how good will these be? and can I wire them into a alarm???
Silvia2b
yes these could be connected to be powered off of a typical security system. Mretty high quality products. We install a lot of the doore actuators, when Installed correctly, I haven't seen very many seize up. But that is the only problem I know with those style door locks.
