DeXteR »
https://forums.nicoclub.com/dexter-u32945.html
Tue Mar 04, 2008 5:01 am
No, I did the door swap.
Answer 1Depending on the trim level of the coupe you're swooping the doors from, it is simply a bolt-on, plug in affair. You may need to splice in a different connector from the door wiring harness if they don't match. It's really easy.
Answer 2Sure, swap the cylinders. I have not yet done this, but it's something I have intentions of doing in the future. Either that or finding a coupe with matching steering column, doors, and trunk that I can just swap over... I don't know how hard it is, but it'll be worth the effort to only need one key for everything.
Answer 3Probably. Would it be worth it? Probably not. I think you'd be better off just finding a set of power doors to do the swap with. Just be patient and find a set of clean power doors from a coupe or hatch. You'll save yourself a lot of time and headache.
Just my $.02 - take it for what it's worth.
