manual conversion: does year matter?
cyrus240sx
Car: 95 240sx with five lug swap, rims, suspension, I H E, remote start, too bad its auto
im trying to figure out if the parts for a 5 spd conversion from a dohc s13 will work in a s14?
PMan_S13
Car: Building car -> breaking car -> fixing car -> start over
the only thing I've found that is really different is the driveshaft for the s14 is longer. Whcih means that if you try to use the s13 5 spd driveshaft that is it not long enough to reach the differential.
Otherwise, the clutch pedal, clutch master cylinder, and transmission all are the same.
I'm putting all my stuff in for my own swap this coming weekend.
SHIFTrl240
Car: 1990 SR20 Sil-80
2009 Yamaha RoadStar Warrior
2017 Alfa Romeo Giulia Ti AWD
the driveshafts do not interchange due to the carrier bearing being in the wrong place.
also, there is a sensor on the top of the s14 transmission bellhousing that the s13 doesnt have.
PMan_S13
the driveshaft won't interchange anyway because it is too short
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
yeah, the s14 trannies have a cutout in the bellhousing for the Crank position sensor.
-Dan
cyrus240sx
so then i need a s14 transmission and s14 driveshaft.... but everything else can be s13?
