That makes baby Jesus cry.WDRacing wrote:Here's a link for yahttp://www.turboxs.com/SBCinstallation.htm
A EBC will be more complex to install. In addition to the same vacuum connections as a MBC, you have to wire the display/controller to the solenoid. So if your looking for 'easy to install', the MBC is better.IanS13 wrote:just because am to afarid to install this i'll just get the greddy i have spent so much money already i migh as well spend a next $400 for the damn boost controller.
No offense but that statement is extremely ignorant. In fact, almost every pro drag car in the NHRA uses a manual BC. How could that be if they suck? There are several manual BC's that have 2 stages of "on the fly" boost setting changes.drifts14x wrote:Digital Boost Controllers are soooooo much better, I know that Manual is cheaper, but don't sell yourself short, most boost controllers have features that justify their cost, like on the fly boost setting changes, and monitors for everything. Do the right thing, I was swayed too, but go to the light with a real, Electronic Boost controller.
Could very well be true. But even if so, a couple hundred RPMs in quicker spool isn't going to really be noticable. I'm not saying EBCs are bad, just not really worth all of the money.SloMoe wrote:It is my understanding that an electronic boost controller has the ablility to hide the wastegate signal until the turbo is fully spooled. Other controllers gradually open the wastegate as boost rises so its full open by the time you reach the desired boost level. The problem with gradually opening the wastegate is you're wasting exhaust gas energy that could be used to spool the turbo. This is why electronic controllers usualy allow the turbo to spool faster. However I could see a problem of boost spiking with an electronic controller if your wastegate is slow to open.
where is the vacuum line coming off the turbo at on the stock t25???.....the only line i can see is the wastegate line coming from the actuator.....?IanS13 wrote:how do i install a manual oost controller do i just put it in the vacuume off the turbo then the oth end into the waste get inlet port.
