AustinSilvia »
https://forums.nicoclub.com/austinsilvia-u13268.html
Sat Dec 04, 2004 10:14 am
my friend got a $10.99 mbc on ebay and the spring came set at 10 psi as the lowest setting. he has no problems with it. it makes his turbo spool super fast (no creep), and he gets loads of power all the way through the rpm range (for a d16 del sol engine with bad compression it is fast... his clutch can't hold down the power). power comes very early too.anyway if you're going to get one check to find out what the lowest setting on the spring is, and purchase accordingly. my friend almost blew up his engine at first because he didn't know the spring rate and the thing boosted up to 15 psi in a heartbeat. how his engine didn't blow up is a mystery, and you probably won't be as lucky if you make the same mistake. anyway it runs fine and he has no problems with it at all now that it's set properly. rotaries are touchy engines though, and the computers are tuned for the turbo to spool in a certain fashion (not as fast as i am describing...). the guy i am talking about with the del sol also has an '93 rx7 twin turbo. his free flow exhaust alone makes the thing spool a lot faster and the stock ecu is not calibrated to handle fast spooling. anyway he has to be careful with it because it can run super lean in an instant because of the free spooling turbo and no fuel compensation. i'd say you will need to ensure your car is running rich before you turn up the boost with a mbc because that free spooling could blow your engine up. there could be a big difference between the newer and older rx7's though, so i'd say read about them and get as much info as you can before trying this.
