manual and power locks - the same?
SunshineAcid
Car: 89 240sx Ka24de swap
i have two 240's and one is about to go to the junkyard. i pulled the manual locks out of it to get rekeyed.i havent pulled apart my running 240's power locks to see if they are interchangeable, but i suspect they are. any of you guys have any info on this? iirc there is no difference in the actual locking cylinder
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Im pretty sure the door frames and door handles/locks are the same. You should just be able to take out the power lock panel and mechanism and replace them with the manual stuff.
SunshineAcid
gracias
slow s13
Car: cars, photo, music
yep there are rods that rod from the actuator to the lock assembly, the locks themselves are the same
