Dont waste your time with Group Buy's we appreciate the gesture but CA members are pretty cheap. Im sure Boost Boy can tell you the wonderful experience he had with his Cam group buy.hydra wrote:R34 GTR,That's precisely what I thought. At what rpm do you get 1bar of boost with your setup in say 3rd gear? The removal difficulty is a none-issue for me. I'll probably ceramic coat the manifold when the time comes to install my (already ceramic-coated) turbo.
About that intake manifold, I'm talking to the manufacturer about the possibility of setting up a group buy. So far it looks like we can get him down to the low-$400 range if there's enough interest. IMO this manifold looks better (from an aesthetic point of view at least) than the CPC manifold in addition to being significantly cheaper. While there don't seem to be any flow-#s published, this manifold has the same design-features as other "brand-name" manifolds with excellent published flow-distribution between the runners. And from eyeballing the pics, the runners look to have an overall length that correlates well with what my engine simulation program tells me is ideal for a CA18DET revving to 8000rpm...
Cheapy-cheap indeed! Hey Hydra, go do your own thing and share your findings. With the CA, the open market is in and big name dealers and tuners are literally out on this platform. And a groupbuy around here for an intake manifold is pointless. Most folks are struggling to get their CAs to run successfully and consistently. Good luck on whatever you do, but please don't disturb the fish with the mentioning of a group buy.The_Chosen_One wrote:
Anyways just because something looks like brand name stuff does not mean its gonna perform like brand name stuff. If you're not making power than buying a IM wont do much. Money better spent will be in Head, Turbo, Tuning, etc etc.
That's precisely what I've been arguing against. Installing a short-runner intake manifold is supposed to show substantial gains once you hit the 300bhp mark on a CA. Just look at the profusion of aftermarket short-runner intake manifolds for turbo engines (CA18, SR20, RB2x, 2JZ, VAG 1.8T, 4G63, EJ2x, etc...) and you will see that they all share the same basic design. Check this link if you still need convincing, the results closely match what my engine simulation program used to give me: http://www.magnusmotorsports.c...m.htmks13 wrote:as Meminto has suggested, intake manifold is only needed when you have a head/cam/turbo combo thats flowing high CFM's.
It's a patented process that is done by one company.ks13 wrote:Is an extrude hone something that can be done locally, i.e. phonebook, or something done specifically by one company?
I guess the ???? is why bother the intake manifold when it is not as restrictive as one may assume. I don't think most around here haven't the slightest idea of what 400whp out of the CA even feels like. But most start building this and buying that because of the name brands that produce said products and using the old theory that if "I spend a bunch of money on expensive parts, my car should be making x-amount of power" .hydra wrote:Did a quick search but couldn't turn up anything so I must ask you this;How much boost was he running? Which turbo was he using ?At what rpm did he get peak power?
It is very much possible to get XXX bhp from a CA on the stock intake, but this doesn't necessarily mean that a) you're going to end up with a remotely reasonable torque curve, and b) you wouldn't have made even MORE power by switching to a short-runner intake. You know I could be very wrong about all this, in which case I'd be happy to eat humble pie, I would just like to see conclusive evidence...
lol... hoping to find someone here to back up your theory?Vetal wrote:Same question about intake. As I understood by reading gurus' comments, such manifold won't give me much even at 400+ HP?
P.S. Does anyone know how even is flow distribution between cylinders with stock intake manifold? I suspect #4 running much higher flow thus leading to #4 burning more frequently
Didn't I mention this is A.Bell theory? I apologize... The book is "Forced induction performance tuning", I really recommend it - very good read.niscort wrote:lol... hoping to find someone here to back up your theory?
As I posted "elsewhere"... the flow testing done on the stock manifold by Ariel when doing r&d on his custom intakes produced data showing the 4 cyl being 6% down compared to 1,2 & 3 when tested @ 25"
