hysteria »
https://forums.nicoclub.com/hysteria-u25294.html
Mon Feb 07, 2005 1:51 pm
cheapo ssautochrome makes just what you're looking for.
many people knock em cause it's "cheap" but i and many others have had no problems with their manifold's, downpipes, exhausts, turbos, etc.... look on ebay. they are easy to find....
they come with the egt bung already installed on the manifold. i am not measuring egt so i had to close mine off with a pressure fitting from winkleys auto parts (a local shop, because home depot didn't have the pressure fitting i needed).
if you get one just make sure that you make a brace for the downpipe and preferably a engine torque damper... ka's have crappy stock motor mounts that let the engine move a lot... if it moves and the downpipe and manifold don't like it they will break for sure... if you skip on the downpipe brace you are asking for a cracked manifold. i braced mine down at the bottom where the block meets the transmission.
