GraySilvia »
https://forums.nicoclub.com/graysilvia-u3605.html
Sun Dec 07, 2003 9:35 am
The only way i've gotten that little tab off is with pliers, and that was with the turbo assembly out of the car.
Cricket noise, eh? My car did that when the exhaust manifold to turbine housing nuts came off (apparently the brass nuts that come with autozone studs don't like hot turbo cars). So, the gasket between the two began 'reeding' or whatever when sufficient exhaust blew threw it, making a cricket noise. I'm guessing you have the exact same problem.
