Manifold leak?
MJ-G35
Car: 2004 G35 coupe
Hello. So when I step on the throttle I can hear this air noise along with the normal engine noise, and I seem to be burning a bit more fuel than I'm use to, which I know is a variable in most situation. I was wondering what this could be... Manifold leak? if so could it be messing with my air/fuel ratio causing more fuel consumption?
Thanks.
audtatious
Could be anything, have a buddy listen for it under the hood as you rev or put load on with the brake (if auto)?
Welcome to NICO
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
Do you have an aftermarket air intake system?
