hysteria wrote:i don't personally know of any ka manifolds that are flanged for t25's or 28's other than that ssac one. but i imagine that if you wanted someone (a professional welder with access to a tig welder for example) to modify a manifold for you it wouldn't cost too much.... if you got the flange and did the cutting it would be a very quick welding job... just make sure the flange sits on there with the angle you need. on the other hand you may even be able to coax IAP into giving you an incompleted manifold or even welding it for you for a little extra moneywere you thinking of upgrading the turbo anytime soon? i know all the stuff you've been through and i know that spending more money on all that right now probably doesn't sound appealing so i'm not going to just spurt off a bunch of manifold manufacturers because i know you're probably on a tight budget at this point (i know i would be) but my reccommendation is that you upgrade the manifold when you get a different turbo... but i mean what is the condition of the t25 you have? is it worth keeping a long time? what are your long term plans, or goals? i know you are aware that the t25 you have won't go much further as far as upping the power output is concerned, but of course there are t25 based upgrades that will definitely do the job... i mean i guess that you'll be fine either way but i mean it just a lot of custom work unless someone else can chime in a give you a bunch of t2 flanged manifolds i am not aware of, or something to that effect.
That is very true...I guess it would make more sense for me to just upgrade the turbo and manifold...as turbos aren't THAT expensive. The T25 I have is good, but as for how long it'll last? my guess is as good as anyone elses. As for long term goals - I want to eventually rebuild my motor and get 450rwhp down....which would cause me to re-do pretty much everything anyways. Right now, I'm just leary on throwing more power into the motor, as the compression test was kinda low....but i suppose it would be a waste of money to just get a manifold for my T25, and then have to get another one for a different turbo later on.
So here'll be some more questions then. I currently have a bottom mount set up - are there any advantages or any new things I'd need to buy for me to convert to a top mount? (other than the obvious top mount manifold), also what is a good turbo to get 450rwhp out of, without having to beat the **** out of it? - and then a manifold to support that?.
When thinking everything over and looking at the situation I'm in right now, I think it would be most wise to start buying things piece by piece, and hoping my current set up lasts me until I can get mostly everything I need at my house, so when the inevitable happens, I'll be ready - or if it lasts until I get it all pieced together - even better.
Thanks for your response - it does make ALOT of sense to start buying what I want for my future goals, and waiting until I get it all to put it together, than wasting money on something that isn't neccessarily needed on a set up I'll end up scrapping soon enough anyways.
