gisdude »
https://forums.nicoclub.com/gisdude-u99964.html
Sun Jan 04, 2015 1:39 pm
Hi all,
I'm having to replace the manifold gasket due to oil seepage/leaking. It's a small leak, but there is some smoking starting to happen.
I count 6 electrical connectors/harness on the cover, BUT I CAN'T SEEM TO REMOVE THEM. I know I've done similar connectors before, but I can't get them to come off. There is a small "hook" in the center that I thought you're supposed to depress, like with a screwdriver, but this doesn't seem to be working. When I've googled, it seems like people use needle nose pliers to press that center "hook".
Any tips here.
Thanks,
