Lowest common denominator. I've been behind more than my fair share of cars that had visibly low tires. The problem is that that's awfully under-inflated, a tire could low by 5-10 PSI and not show any visible signs. Additionally, tire pressure decreases by about 1 pound per square inch for every 10-degree drop in outside air temperature - I'm willing to bet there are plenty of drivers that have checked their PSI on a fine Indian Summer day only to have the tires be super low when the sun goes down and/or a cold front moves in.smash209 wrote:Why is the stupid Tire Pressure Monitoring System now required by law "for saftey" but ABS which is much more useful and increases safety not required?
How often to do you do it? And are doing it with this:smash209 wrote:I can check tire pressure with a gauge very easily.
Sounds like what you really need to be upset at are drivers not using turn signals. They've been original equipment on cars for years.smash209 wrote:I cannot however, predict when someone will make a left-turn across two-lanes because someone waved them on!
TPMS is only required on new car purchases. Since the average American rarely checks their air pressure, having an early warning system, like an low oil or low fuel idiot light, is a nice little feature to alert you that something's wrong. If you happen to have a TPMS on your car and it offends you THAT much, just disconnect it. I happen to like my TPMS (which displays pressures on each tire) as it enables me to watch tire pressures during track sessions.smash209 wrote:Why is the stupid Tire Pressure Monitoring System now required by law "for saftey" but ABS which is much more useful and increases safety not required? I can check tire pressure with a gauge very easily... I cannot however, predict when someone will make a left-turn across two-lanes because someone waved them on!
themadscientist wrote:The simple answer, government. It's a wide-ranging multi-tiered idea that covers a plethora of sucky ideas.
My wife's car has a tire pressure monitoring system, she calls it Mike.
You nailed it!Rex wrote:It's informative without being intrusive. And it is a safety feature that is most beneficial when "at speed".
I could understand complaints about TPMS, if they prevented you from operating the vehicle if the tires pressure was below the minimum. Now that would be a problem for any one using (winter) wheels with no TPMS.
Background: As a result of Run Flat tires and their ability to sustain ~50 miles and non-highway speedswith little to no feedback to the vehicle operator, there had to be a way to let the driver know if the tire had become punctured (but not a blow out) while driving. That's part of why we have TPMS.
I realized it's being used more wide spread than this, but that was one of the initial reasons.
I'm surprised no one said anything about this.smash209 wrote:ABS which is much more useful and increases safety not required?
Ideally.Rex wrote:It's informative without being intrusive. And it is a safety feature that is most beneficial when "at speed".
Probably because not everyone agrees that ABS is more useful or incrases safety. There are plenty of examples where ABS is NOT a good thing (icy roads, for instance, or snowy roads with good siped winter tires). ABS also encourages bad driving habits because it teaches people that they don't need to modulate their brakes themselves. Just push really hard and the car will do it all for you.Dattebayo wrote:I'm surprised no one said anything about this.smash209 wrote:ABS which is much more useful and increases safety not required?
That's more or less what I was getting at. I remove ABS from all my cars if and when they have it...MinisterofDOOM wrote:There are plenty of examples where ABS is NOT a good thing
Oh. Right. I'm a dope. I completely misunderstood you.Dattebayo wrote:That's more or less what I was getting at. I remove ABS from all my cars if and when they have it...MinisterofDOOM wrote:There are plenty of examples where ABS is NOT a good thing
Who is able to disable it? You can't, short of pulling the dash apart to unsolder the led, and its illegal to do so. We are lucky we don't drive Corvette's, because if your car has the tire light on, it also goes into "limp mode"! Also my gripe had nothing to do with turn signals.Bubba1 wrote:If you happen to have a TPMS on your car and it offends you THAT much, just disconnect it.
my biggest gripe with dtrl's is that it doesn't turn on your tail lights (at least in my mom's lancer). when it gets dark, they see their headlights on and forget to turn the switch to also turn on their tail lights. after constant reminding from me, my parents now switch on all their lights automatically, but i still see plenty of people on the road who don't realize they still have to turn on their headlight switch when it gets dark.Bubba1 wrote:As far as daytime running lights, the reason you don't see them that much because it's (1) its voluntary, and (2) I believe NHTSA did a study and concluded that in cars they did not significantly reduce the chances of crashing as compared to not having it.
Keep in mind, ABS systems have been evolving/improving since the 80's/90's, It seems to me the odds of an ABS system failing, like your dad's trailblazer, are pretty slim, epecially if it's a newer model. Clearly no system is perfect, but I don't think you can ignore how few ABS failures there have been relative to the tens of millions of vehicles that have it. And since you're an experienced driver and learned to drive without ABS, then I would think if you were among the very few that experience an ABS failure, and it suddenly becomes a non-ABS system, that it should be pretty much a non-issue as you already know what to do.MinisterofDOOM wrote:How about the time the ABS in my dad's Trailblazer (a truck, mind you) kept going wacko and randomly pulsing the front left brake while at speed (on the freeway among other places)? Why? Got coal dust in the ABS sensor. I guess it's a good thing no one takes their trucks off-road anymore, because a little dirt seems like a quick trip to malfunction land. That's a pretty cool failure to have for a "feature" whose benefits are debatable. Nothing like being jerked into the next lane by YET ANOTHER electronic babysitter. A less experienced driver might have wrecked. Just what I need, little old Miss Camry having her ABS go haywire and driving into me.
Or the time the ABS on my Q45 decided that snow on ice was confusing and thus simply refused to brake hard enough to stop?
Or how about the ten million times I've stopped safely in snow and ice and rain and any combination of the above in my Maxima, my Ranger, or my Q45 all without ABS?
That's why I hate ABS so much: only thing it's ever done for me is cause new problems I wouldn't have without it.
If I'm so inept I can't stop properly without ABS that's one thing. But when ABS steps in and fails FOR ME, when I'm completely capable, that's absolutely unacceptable.
