IslandBoy wrote:I know a few guys who had a memory problem with the Power FC. There always loose the settings every time the car is switched off or the battery is removed. These were with the RB26DETT and the RB25DET which were installed in different cars. Any reason for this?
due to the efi harness not being wired up right.powerfc needs to see the key turn on and off for it to save properly, most people wire this into the the switched power when it needs to be constant for it to save...nothing wrong with the pfc, just the wiring.
