LER »
https://forums.nicoclub.com/ler-u7745.html
Wed Jun 04, 2003 7:22 pm
ok i drive a 91 240sx with a 93 engine that has about 85K on the odometer, i just pulled my engine to fix an oil leak. before it ran beautifully, but now ever since i put the engine back in at first it wouldnt crank but finally when i get it running it seems ok. well now when i first start up it run like crap and wants to die, i will hold it at around 2500 and it bogs until it stalls. I crank it up it still acts like it is missing. after a few minutes of not being able to rev padt 3 grand it seems to be ok but every now and then after ward it will start to act up again and not rev but then again after a few minutes of trouble its fine. i just put new wires on it and my spark plug are clean. Tomorrow i am going to check the injectors but do you guys know of anythign else it could be? also i closed off the pipe going from my EGR valve to my exhaust while the engine was out, would that cause it to run rough? also there seems to be a short somewhere, when i connect and disconnect my battery a few of my relays kick on and off, with the key out of the ignition, any thoughts? any help is greatly appreciated. thanks
