MAN these 22mm bolts are NOT fun
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
hopefully for everyone's sake it's just my car. I'm changing my front rotors and pads today, and my goodness these 22mm bolts holding inner caliper piece are ON THERE. I have managed to get 3 off, but had to call in air support on the 4th.
Anyone planning on doing this, make sure you have a breaker bar. I broke mine and REALLY wish I had it right now. Just recuperating from another attempt on the 4th right now...keyboard is all greasy, dammit.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
Sounds like there's thread locker on those. I like to use a small sledge hammer for "shock value."
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Cheap tools are great arent they (unless of course you had craftsman or snap-on and you just out-muscled it)
I remember when i did the brakes on a G35... it was hell to get those bolts off, mainly because it was nearly imposisble to get a breaker bar in the wheel well.
paranoidjack
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1996 Infiniti J30
elwesso wrote:Cheap tools are great arent they (unless of course you had craftsman or snap-on and you just out-muscled it)
Good old breaker bar, job was done in 5 seconds to 2 hours of struggling with the damn cheapo ratchet.
Working on cars is such hell with the wrong tools, and so god damned rewarding with the right ones. Can't wait to get my garage in order, just bought a new house 6 months ago.
FarFetched
Car: Suzuki SV1000S.
In my tool box (bus sized roll-away) there are four favorite tools of all times. Sparky (electric grinder), Betsy (approx 15lbs dead-blow) Stryker(Air Chisel with bunch of different adapters to get the JOB done) and Twisty (3/4 inch HD air impact gun). Along with 2 breaker bars (shortes is 30 inches) I can tame the most stubborn bolt/nut combo in the world. If you want to have real fun , try removing E/F series Ford truck front caliper support bracket ...Cheers!
goody90q45
Car: 1992 Infiniti Q45 (sold)
Working on cars is such hell with the wrong tools, and so g** damned rewarding with the right ones.
When I bought my Q and began the transformation to a DIY'er I thought I had all the right hand tools until the first time I tried to remove the brake caliper. I found out real quick that I needed a 1/2" drive ratchet, socket set, extensions and breaker bar for the big stuff, and a 1/4" set for the small stuff. These should be in everyone's tool box.
Happy Father's Day to all the Dads out there.
paranoidjack
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1996 Infiniti J30
goody94q45 wrote: Thanks man!
