making turbo manifolds from scratch
TomsMR2
Car: cars.. etc
for mild steel manifolds.. what are you guys using?
i can weld 1/4 steel... maybe a bit thicker, im not positive.
so i was planning on getting a 1/4 inch thick strip of steel, tracing the flange and drilling it out. then welding unequal tubes to a flange, top mount style.
things i should look out for? suggestions? too thin? thanks :)
WDRacing
Needs to be bigger then 1/4 inch I think, I'll ask my metals tech guy tonight and get back with on that.
WD
TomsMR2
Car: cars.. etc
.. thinking about it.. i think i can go thicker than that, regardless of the welder. i think i can go upto 1/4in on the actual runners (which is overkill :P). i think i could run a 10 inch thick (theoretically) flange with up to 1/4 inch runners and the weld would hold.. i think.
if you could get a definate answer tho, that'd be really helpful, thanks WD :)
cfinch
http://www.sdsefi.com/techheader.htmIm building my header similar to that the bends cost me about $5-6 each 12 - 90s and 2 45s i needed 4 of the 45s and 10 90s but i spent all day finding a piping place that caried them and thats all they had. I had a local shop order me the flanges for my car for $55 for both. It wound up being about $135 alot better than $5-600 and all you need is to weld it all together. I get my flanges friday and start working on it ill post up some pics of how it goes.
hannibal
Car: Red Line to Glenmont
This site sells manifold kits. It comes with the exhaust flange, 2 90 bends, 2 T sections, and the turbo mounting flange. You just gotta weld it together. IIRC, it uses 1/4" thick piping.http://www.iboost.orgSite is under construction. Not a whole lot of info.
SingleCamSam
What kind of welders are you guys using for this? I have a handler 175amp MIG welder, think it'll make strong enough welds for a manifold?
TomsMR2
Car: cars.. etc
^ thats enough to melt your manifold in half.
WDRacing
My buddy says 1/4 will work but he'd use somthing thicker do to thermal expansion and what not. Also, make sure you cut some thermal reliefs inbetween each runner.
WD
U12 2NR
iboost seems to be garbage...most of it isn't functioning. good luck getting a phone number to call. anyway jgstools.com sells unfinished log manifolds. they also sell the head flange, which i bought, it's worth every cent. now all i have to do is the tubing, which i've already done, i just need to weld it up. tracing out your own flange is rather easy, but i didn't want to be bothered with having to drill the holes (don't have a drill press), nor machining it to be flat.
TomsMR2
Car: cars.. etc
im gonna drill the holes with a hand drill....
U12 2NR
it's a bit more tricky than that man, if you're talking about SOHC KA. You can't use use a strip of metal, it has to be cut to make space for the spark plug wires. Using a regular drill will work, but if you see the CNC cut one from JGS tools, you would ditch that idea instantly, guaranteed. 1/2" thick stainless steel, perfectly matched holes.
95_240sx
Car: My baby (car)
I have a JGS on my car and it is extremely high quality, except i couldnt get my turbo to fit without modifying the flanges they give you to weld onto the manifold to let them set down higher up.
Rick
SSS
TomsMR2 wrote:im gonna drill the holes with a hand drill....
Go and spend the money on a bench top drill press. They're not that expensive.
TomsMR2
Car: cars.. etc
a hole is a hole is a hole. why do you think a press would do any better of a job? granted, its easier, but thats about it.
TomsMR2
Car: cars.. etc
some clown is always like "oH YoU NeEd SpEcIaL ToOls To Do It!!1" . then people believe that. soon people are gonna think you need full CNC lathes to change your oil.
SSS
Sorry TomsMR2, i just thought that for the $40-50 USD you can buy a reasonable bench top press that would make the job go heaps quicker and would be a bit more accurate, less time you have to spend with a die grinder on the flange later on.:)
Xero
wait, you DON'T needa CNC lathe to change your oil? DAMN!! what about a mill? can a CNC mill change your oil?
BTW, you CAN do it with a a drill, but the mill is still gonna be more accurate, I wouldn't want my hole to be off center and have a nasty exhaust leak at the manifold,
HOWEVER!!!! just make a jig, for those that don't know what a jig is, it's a fixture that guides the cutting bit, a fixture just holds a part down (gotta love being a Machinist, huh?) just make sure that hole going where you want it, take the time to do it right the first time,
SSS
Yes. yes, that would work too. :rockon :D I would probably go down that path Xero, all depending on how much i was charged for it.
U12 2NR
JGS flange:
http://www.hipershine.com/Stan...1.jpg
http://www.hipershine.com/Stan...2.jpg
http://www.hipershine.com/Stan...3.jpg
I'd like to see hand tools do that.
Why spend money on tools (even a drill press) unless you'll need to use it again down the line? I don't like to buy tools to only use them once. For the price of a drill press you can have the JGS flange already cut perfectly. Anyway..making your own keeps costs down so best of luck.
Xero
SSS wrote:Yes. yes, that would work too. :rockon :D I would probably go down that path Xero, all depending on how much i was charged for it.
just make a jig, don't pay someone to do it, or am I misunderstanding your post,
IowaSilvia_S13
Car: HMM... IMPORTS IMPORTS IMPORTS
people with no mechanical inclination need not apply to this thread. If your not a tool maker, cnc machinist, etc. Shut the F up. You don't have a clue. Don't buy a drill press and try to make your own flange. You'll prolly get hurt free floating a 1" hole in it any ways. I'll start making them for you at work and sell them to you. I'll profit and you can buy .. how's that
Xero
personally, I looked at the JGS Tools manifold, and that's what I'm going with, $250 and I can mount it any damn way I please, top mount, bottom mount, whatever,
IowaSilvia_S13
yeah.. but you're a machinist right? no prob. for you or me to do that...
U12 2NR
iowasilvia..you're one cool guy. i wanna become a machinist just like you, but i gotta study hard. wish me luck.
Xero
but this is a thread about making manifolds from scratch, so I'd assume that people would have some sort of mechanical or fabricating skillz, then again, Iunno, I see where your coming from, thank god I chose this as a major, woo!! start college this fall, woo!! already got 450hours, woo!!
TomsMR2
Car: cars.. etc
im confident in my fabricating skill... maybe i dont do it the *right* way, but its my way, and it works :)
if the end product works, i dont care how i got there lol.
and $40 drill presses? i was under the impression they were in the hundreds... you cant even find a decent hand drill for 40 bucks, much less a press.
TomsMR2
Car: cars.. etc
i dont post in your toilet, dont **** in my thread
Xero
if your gonna do it yourself, my suggestion is a jig, or something so you know that the hole won't be off at some odd angle, and not make a good seal with the head, but it can be done with a hand drill, it'll come out fine,
and yes, drill presses that are worth anything are pretty expensive,
