Rookie_ca18 wrote:Tight, how long did it take to port and polish it. I think you said you were gonna do it yourself.
I put around 4 1/2 to 5 hours into it, but someone who'd done it before could probably run through it in three. The porting I did is minor though; I spent most of the time grinding out internal imperfections with sanding drums and a stone and running flap wheels through everything. If I get the time I'll put another hour or so into it with a 120-160 grit flap wheel as I only had an 80 at the time.
If nothing else I think it was worth spending 15 minutes with a flap wheel and some compressed air to knock out the carbon that had built up inside. The clouds of black soot that shot out of the passageways were pretty unpleasant.
