Sil240 »
https://forums.nicoclub.com/sil240-u6842.html
Mon Jul 06, 2009 3:50 am
Check out ATP turboThey have the Ultimate Internal Wastegate.It has a Vband connection if you don't want to use that External.
I have one it fits mint!!!The vband is def nice too, makes taking the DP off a bit easier.
I think they also have a block off plate with a vband if you are going to use that external.But you will have to re-route that pipe into the DP if you don't want to run a screamer pipe.
