DukeBoy wrote:I have had the same problem with a customer of mine with megan header and stock t25. I have replaced his gasket numerous times and i recently changed it the other day. He has gone through stock nissan gaskets (the thick good ones) as well as the megan ones. I replaced that turbo gasket on tuesday with a new megan one and it was leaking by wednesday. The entire back section of his gasket was gone now. I replaced his studs with stainless studs and brand new oem locking plates. He brought it back and said it was leaking, but when I tried to tighten the nuts, they were tight already. He has an ebay downpipe and it doesn't line up with the rest of his exhaust. I'm thinking his downpipe is putting too much stress on his turbo due to the misalignment of the rest of his exhaust(Greddy Catback fits perfectly). That and his motor mounts might be bad and causing more stress. I'm ready to weld the header to the turbo inlet but It shouldn't require welding. I have had my gasket in my car for over a year now on a rebuilt motor and rebuilt turbo with stock manifold and a bee*R misfiring system and I havn't had any of these problems. I am at a loss too and I cant afford to keep working on his car.
well duke...i really hope im not jinxing myself by saying this...but i think i (crossing fingers) i found out why this problem keeps happening on our cars with this setup (or thereabouts)...the issue seems to be the nuts want to back out because of extra stress from down pipes elbows etc...what i have done is
"phase one": to use the locking tab plates, all new studs>>>>spot welded these to the top of the manifold!!!<<< (on the mani/turbo) HERES THE KEY THING...i filed down the manifold and turbo flanges so to ensure proper sealing due to being flat...because its stainless its tends to warped under manufacturing heat...the nuts i used on the new studs were the oblong shaped locking type...i built this assembly out of the car..wrenched that "ISH" down as hard as my hands could, and put it back in then moved on to
"phase two": i purchased a second flex pipe from summit racing, cut my exhaust piping, realigned everything with the second flex pipe, and rewelded it back together...i also added an extra exhaust pipe hanger near the gas tank to keep things more stable. i then made sure the existing hanger setup was atatched to the proper transmission mounting point (welded another hanger at the location) and well so far a day later its holding strong.
KEY POINTS are to make sure your exhaust can flex WHERE it needs to but not place stress on the turbo/manifold assembly. and also keep those nuts on there tight. WERD!...let me know if any of this info helps you out...feel free to ask me questions if you need...or if you want to see some pics. i will be happy to take some and shoot em over to ya. good luck!
