9sec240 »
https://forums.nicoclub.com/9sec240-u32495.html
Wed Feb 28, 2007 8:06 pm
We have packaged the turbo kit three ways.
One is a complete kit including manifold, turbo, WG, DP, dump tube, feed and return lines, gaskets, etc.
The second way is Manifold, DP and Dump tube. This allows you to purchase and fabricate the rest of your turbo kit on your own as long as its a T3 5 bolt discharge turbine housing.
The third way is just the manifold alone. This way you can run a 4 bolt discharge turbine housing if you like and fab your own DP.
Check our ONLINE STORE for details
