Mettler wrote:The intake ports on the USDM VH41DE differ in size and shape to the JDM VH41DE.
The way you have your runners there looks as though the air will hit a 120 degree bend upon entry into the head.
I'd be inclined to have the runners the other way around (facing outwards) to suit the port entry angle.
What I am using is 2 stock passenger side (right side of car) manifold halves. The runners line up perfectly internally.
Just the way the Y33 motors were designed I guess. The right side is exactly as it was from the factory, but the left side now has a straighter shot into the cylinders than the original setup because the original runners on the right side did a 180 from the plenum, and then ran low, and had to turn downward into the ports. This design is the straightest runner design possible on this motor.
Also, could someone let me know if the spider intake VH41's have the same port layout as the 'mustang' intake like mine?
Mine looks like this concerning the bolt patterns
I know all the VH45's have it like this:
Modified by SeanDean at 1:10 AM 10/4/2007
