Nelson, a PCV setup when functioning properly shouldnt see any oil at all. I know mine didnt, but it saw its fair share of black gas when i had blown injector drivers(which is what you want). Doesnt mater that some oil would mix with gas, they would still drain right out.
Your buddy has other issues that were causing excessive blowby to create that situation.
Honestly the best mix is to have your valve cover breather hooked up to a catch can, then to your turbo intake. Then have your PCV valve set up like this. PCV valve ---> Catch Can --->McMaster check valve ---> Stock goofy 1-4 rail --> Intake manifold. This gives you the best of both worlds with a PCV setup.
Another good way is to take your PCV valve and rout it directly to your exhaust using the venturi vacuum effect. Still have your catch can connected to the valve cover and pre turbo.
Chris28 wrote:What is a baffle. I'll take Countries for 500 please.
Lol
This country's residents drive on the left side of the road, and houseD one of the most dangerous and violent terrorlst organizations in the world.
