I don't understand, he said he got a greddy tune for 8 psi so he should be good. His tune is reading is the air flow from the mafs not what kind of turbo he's running. 230rwhp does seem low for a t4 on 8 psi tho480sx wrote:Your lucky you didnt blow the motor. You need to get that tuned dude, dont drive in boost untill you do. 8 psi on a t4 turbo is much different than 8 psi on a t25.
No. You don't have to do anything.Supra_turbo wrote:damnit so technically i got go have a dyno tuner check my tune and make the proper adjustments... IF theres any
There is without a doubt, 100 percent sure adjustments that need to be made.Supra_turbo wrote:damnit so technically i got go have a dyno tuner check my tune and make the proper adjustments... IF theres any
Well he never said that his car was running like crap, we just kinda assumed that there was something wrong cuz of the weak hp numbers. I know where you're coming from, I would want to know the cred. of the guy who tuned it.480sx wrote:I mean going on what he said, it just sounded like a shadey tune. From some random guy with some random car. You never know whats in there, and to start boosting without knowing your in safe AFRs is not what you wana do.
A t4 compressor wheel moves more air at 8 psi than a t25 at 8.
Good advice from all thank you much.. A wide band will be invested in and very soon =D sounds like a serious necessityWDRacing wrote:I dunno where you guys are getting your numbers from. Over 200 whp on 8psi of boost is good. That means it's running safely and actually making decent power. 99% of people think they are making more power then they are. Whether it be tuning or the dyno itself...people are almost always wowed by how much power they aren't making.
230 in a S chassis is a fun little daily driver. Especially since the bigger turbine has a "flash" spool effect.
If you want reliability, you really need to do as suggested, get a wide band and see what the AFR is on and off boost. If it's in the 11's on boost and it's running smoothly, then leave it. Your best bet is to post the AFR with a dyno chart so we can best assist in the tuning. Just remember, rich = safe.
Also, as a rule of thumb the increase in whp is about 10 per lb of boost. If you're close to that window then you're doing well.
WD
I never assume someone would install a T2 framed turbo. When I explain something I usually assume that people are going to run atleast a semi efficient turbo. Also, numbers don't really increase when switching to larger turbo until you're running quite a bit more boost. Even a small T3 is efficient at 8psi. But anything over 8-10 psi will always lend to the bigger turbo.Titan wrote:"Over 200 whp on 8psi of boost is good."
Pressure means nothing without flowrate. 8 psi on a T25 is completely different than 8 psi on a T4. Worlds apart in terms of moving air. This is because we are dealing with dynamic (moving) air, not static.
Also, this is why air tools, for instance, are rated for flowrate (scfm) as well as operating pressure.
That being said, 200 rwhp at 8 psi on a T4 is low. I hit just below that on my T3 at 6 psi.
To the OP: Not to sound like an ***, but you're asking how to keep your motor reliable, yet your emanage is supposedly tuned? Get yourself on wideband and make sure you're seeing approximately 11.5-11.8 at WOT. Keep off the pedal until then.
