evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu Apr 23, 2009 7:22 am
sounds liek you found the basic info, the easiest way to add the turbo is to locate a complete wrecked 82-83 280ZX Turbo (81 works too btu the wiing is a bit different), it's far easier to swap the complet engine form a donor than to convert your engine and likely cheaper, I've bought a few wrecked turbo cars from $350-500 each, and you can sell off unused parts to offset the cost and likley end up wiht the donor for free
if you wante dto convert your motor you's need:ecuharnessdistributordistributor driveshaftAFMoil "T"oil hard lineoil panoil pump is remomended but not neededturboexhaust manifoldintake manifold"J" pipefuel injectorsfuel pumpknock sensorCHTSand you'll have to lengthen the chts wires to reach the chts which is in a different postion on your motor
if you knwo what you are doing and wante dto upgrade a lot of those parts can be substituted, stand alone engine managment will replace the ecu and likely you'll have to replace or at least modify the harness, but it will allow you to possible eliminate the afm but you might have to add a sensor such an a map, this will also allow you to run different injectors and to remove ro replace the idle air circuit so you can keep your manifold, if you wanted to add an intercoler you don't need the "J" pipe but most people use half of it anyway
but the best way to start, is with a complet turbo donor, evne if you only want the parts, it's likley cheaper to buy the whole car than to buy all the parts
