jrc90240sx »
https://forums.nicoclub.com/jrc90240sx-u355.html
Sun Mar 16, 2003 8:48 am
Well nothing is really cheap, if you want lots of power, and I will even go out and say alot of NA hp is more expensive then a forced setup making the same.
Your car has alot of miles on it, so i would take that into consideration. take me for an exaple, i have spent well over 3k on rebuilding my tired KA24e engine. I wont be putting out lots of power either. so there is alot of money there (SR would have been cheaper and making 50+ more hp).
Its not going to happen over night, even though some may wish this.
What I would do is start with upgrades that dont mater if you go NA, Turbo, or Swap. So you need to make a list of parts that you can keep for any of the setups, theres exhaust, eletrice fan, underdrive pulley (if you dont swap), ignition upgrade, cheap custom intake (Cone filter, with cheap custom piping setup, so you can keep the filter with turbo, and ditch the cheap piping), Cam (mild and only if your not swaping), cam gears (again only if you dont sway), short shifter, fuel system upgrade (pump, FPR, larger injectors), maybe a ECU retune (again not swaping), LSD, Light Flywheel (if your not swaping). there are some other little things, but they starting really getting expensive. and your really only left with swap, or rebuild.
