Checkered-Member wrote:C-KwikWhich T3 turbine A/R will you recommend for a stock KA24DEthe .48 or .63?
Depends on several factors. Which T3 turbine? There are several trim levels. Secondly, what do you feel is more important? Good low-end turbo response or more top-end power? What are your power goals? And what compressor are you going to use?
Keep in mind I have a bias towards larger turbos. I'd use a smaller trim T4 turbine myself for a street KA(which is what I had on mine). So, as objective as I might try to be, I may end up pushing you towards a larger turbine or A/R.
It's also hard to really describe turbo response as well. Many people confuse turbo response and boost threshold. Larger turbos aren't necessarily unresponsive. The larger size is of course more weight to have to push around, but the biggest factor is that larger turbines need more energy to spin it. But at low RPM's where the exhaust flow is lower, there may not be enough energy. So until you reach an RPM where there is enough energy, the turbo will not spool fast enough to make boost. But once you are above the boost threshold, turbo response is pretty good. You can go from part throttle cruising and smash the gas and as long as you are above the boost threshold, the turbo will respond pretty quickly. I'm talking relatively here though. Larger turbos, again, do have more weight in the moving parts so there is a very small delay, but on a track, you can hardly tell. In exiting a corner, you should be easing onto the gas anyway in the transition from turning to accelerating, you'ld likely never be able to tell.
Honestly, though, the best way to know is to test it out yourself. If you can try to drive or get a ride in various turbo cars, especially cars like your own. Watch how the car responds to the throttle inputs at various RPM. Ask about the specs of the turbine and compressor. If the compressor size and trim are close, the differences will probably be negligible. You'll have an easier time comparing different turbine specs against similar compressor wheels. Comparing 2 different turbines with a T4 and T3 compressor wheel would be a lot more difficult.
