audtatious wrote: ^^^
Dude, I do not believe anyone on here is easily going to give you the infomation as shutting your tail lights off at night is dangerous. It's also just a weeeee bit illegal as well.
Come on, you know me. I'll gladly help someone do something incredibly stupid. I don['t care if it's illegal. It's just stupid. So I'll help.
What you is a high capacity switch. 20~30 amps should do.
The easiest thing to do is to cut the wires back by the taillights. Then splice in a length of wire to run it up to the switch. Then back to the lights and splice it in.
I don't recommend trying to kill your turn signals as this will either require another switch, one for each side, or they won't work properly.
I recommend putting this switch in a location that is very obvious. I also recommend using a switch that glows red when the lights are killed, and blue or green when the lights are on.
