p00t »
https://forums.nicoclub.com/p00t-u5026.html
Fri Dec 12, 2003 10:50 am
i can see the practicallity under a decently boosted KA-T. But under low boost or NA its pointless. KA has serious breathing issues at those higher rpms. To make effective use of a high reving KA you would need major valve work not just springs, extremely agressive cams (3k idle anyone :rolleyes), balanced crank and rods, a custom shortened intake manifold (shorter runners), ported as much as possible and after all this you would lose all your low end power. So what your doing in effect is creating a horribly small powerband probably 5-7k, when boosted the stock 3-6.5k band is wayyyy better. im not saying no to cams and stuff but go get a ca, sr, or rb if you want revs, they were designed with different power band behaviors in mind (which is what really matters, not how far you can bury the needle).
i dont understand why people need to rev high, rpm isnt directly linked to how much power you make, so many more factors need to be taken into account. Look at a KA dyno chart and take a cold hard look at what you are fighting! In the upper rev range 6300+ the torque drops fast because the engine is starved for air. Shifting the power band to the right more is fine, but you reach a point of diminishing returns and sacrafice the actuall usability of the car, have fun doing nothing but drag and high end track use.
You want to rev to 8 grand? Fine, but you better be able to accept the fact that you will be making 15 hp at 8k rpm, be down about $6000, and going nowhere fast.
