blacksrjdm »
https://forums.nicoclub.com/blacksrjdm-u52167.html
Mon Dec 07, 2009 8:53 am
Ya, I'm with Nali. There is no defending him one way or another. "The usual bolt-ons", so, it might have; pointless intake, and maybe an exhaust. I would honestly be suprised if it is lowered and am doubting that he has installed a header. so not going fast enough to need a wing, let alone a wooden wing that is all laquered and so forth... If its a track car, then its an even worse idea. Its just an absolutely terrible idea. Just like the guy with the plywood front splitter. We never saw the demise of his front end, he just kindly went away because plywood does not belong as an airfoil for anything.
Getting back to the laquer... Dont ever turbo the car for fear that if you ever do shoot a flame out of the exhaust, the laquer will go up like the alter in "Meet the Parents". And then you will have a lack of downforce and worst of all...THE BACK OF YOUR CAR IS ON FIRE!!!!!
Give up the idea and go back to the drawing board. Also, Plane props such as the one you showed there in your pic, need to be inspected and changed frequently if the plane is flown often enough. My uncle flies a stunt byplane out of Cape May airport, if you are in the area you may have seen him in the byplane or a low wing pilon plane doing loops and such over the area. But he has several props, that are changed almost everytime he flies to copensate for different flying situations. He also checks and shaves and shapes them. That prop probably weighs around 130 lbs. So bad example.
