to NICO!
It sounds like you have a lot of rehab work to do before you start looking at mods. I'd start with the fuel pump, since you say it's humming. Probably injector issues for the rough idle, and cutting off at stoplights potentially sounds like a bad MAF (mass air flow) sensor connection or a bad sensor itself.
Once you get all of that done - the most effective mods would be the NICO ECU and adding the front and rear sway bars off of an Active Q. Not much aftermarket support for the old Q, and what was there has pretty much dried up at this point.
Good luck!
Heath
