Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sat Oct 12, 2002 2:47 pm
If your Plenum hasn't been off in 7 years or 80k, it is a very good idea to pull it, clean it inside, check all, replace All hoses, examine the knock sensors and their harness etc, because about 1.5-2 hours of the work done to get the driverside valve cover off is applicable to the plenum job.Always a good idea to keep the throttle body and IAC gaskets on hand as they crack in almost any removal!
