Well our trusty '95 SX has developed a water leak somewhere.
I'm out of the country... as usual... and I'm trying to get a handle on the problem via my Girlfriend - who is not technically minded at all - but has managed to take this snap under the car:
There was a water pump swap done ages ago (photo write up here
zerothread?id=232942) but this one is a little bit different.
The car does not leak any water if not used - it just seems to happen when the system heats up.
Can anybody suggest any likely locations for my GF to observe for leaks that would cause that sort of coolant loss seen in the above photo?
I know that's a fairly open question but it might help narrow down the possibilities until I'm home early next year.
I suppose it could even be a hose once the thermostat opens up or suchlike?
Cheers in advance
