grk nickafis »
https://forums.nicoclub.com/grk-nickafis-u138649.html
Mon Nov 30, 2009 5:28 pm
When the car is on the cold side but not Cold, if im just cruising and i put it in nuetral or press the clutch, the RPMs bounce from like as low as 300 bounces up to 1k and keeps doing that untill i pop it into gear. If i let it go long enough it just stalls. i cant press the gas or anything untill i pop it back into gear. if i roll to a stop (assuming it didnt stall), the rpms go back to a steady idle at about 1k. At a cold start (ONCE i did this, only once), i punched the gas from 1.5k rpms and its sputtered its way to 3. I'll try to get a video of this. I mean i have one ill try to post it.
