Major problem with my S13
JayS13Project
Car: 1991 240sx Fastback Base model with issues.
I have a 1991 240sx hatch with vlsd. She was a track car i recently picked her up for 1500. So when i turn whetther its a small or big turn my back tires screech like they are loosing traction and they also do get a little stuck when going in reverse again when im in reverse going straight is fine, but the slightest turn with make my back wheels lock up a bit. Any ideas on what it coukd be? Now there is a hit on the back on driverside. Maybe the hit caused some damage?
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
Are you positive it's a vlsd? It sounds to me like it might be a welded diff.
JayS13Project
speedeast wrote:Are you positive it's a vlsd? It sounds to me like it might be a welded diff.
Well based on the information I was given by the previous owner. It may be.
speedeast
A welded differential will make both wheels attempt to spin at the same speed even if you're turning, when they don't need to because they cover a different amount of ground.
JayS13Project
speedeast wrote:A welded differential will make both wheels attempt to spin at the same speed even if you're turning, when they don't need to because they cover a different amount of ground.
Yea kind of sounds like that's whats going on. It's pretty f*** annoying to be honest. Lol so new diff? Also my transmission seems to be more off to the right and isn't centered.
speedeast
Take a pic. As for the diff, you can grab another one from the junk yard. I would go for a vlsd. It supplies power to both wheels while still allowing for difference in wheel speeds while turning. You can yank one out of a J30.
JayS13Project
I'll take one tomorrow. Anyone local so tgey can really see what It is Im talking about?
speedeast
That depends on where local is
JayS13Project
speedeast wrote:That depends on where local is
Socal la
JayS13Project
Image there's the transmission. See how its off to the right.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Bad trans mount and/or engine mounts. Get underneath there with a pry bar and start check for loose/worn components.
JayS13Project
compactfean wrote:Bad trans mount and/or engine mounts. Get underneath there with a port bar and start check for loose/worn components.
I'll give it a try tomorrow. See what I find. I knew it was off.
JayS13Project
Update. Got the rest of my interior done. :D
inertiadrft
Car: Do NOT be fool'ed by the low post count, The wise choose silence over Bla Bla Bla...
Welded diff!
Lucky you!!
Where in SoCal are you?
JayS13Project
inertiadrft wrote:Welded diff!
Lucky you!!
Los Angeles
JayS13Project
Bad news guys I think my transmission is going out. There's this loud scraping noise when the clutch is not engaged and through 1,2,& 3rd gear the higher the gear the quieter the scrape. Also don't feel like my acceleration is there.
speedeast
How's your clutch pressure? Any chance the pedal needs adjustment (not fully disengaging)?
JayS13Project
speedeast wrote:How's your clutch pressure? Any chance the pedal needs adjustment (not fully disengaging)?
Clutch feels fine for the most part could use a new one soon too though.
