SlidewaysScott »
https://forums.nicoclub.com/slidewaysscott-u33874.html
Tue Aug 22, 2006 3:59 pm
ok this is a long story so please bear with me...
Last week I heard a loud tapping noise coming from my engine. After determining that I had an HLA that needed air bled out of it, I read up on how to do it and looked in the FSM. Timing was already perfect before I did this. After I bled it, I put everything together tourqe'd everything to spec. Turned the engine by hand about 10 full rotations to make sure the timing was still ok...and it was DEAD ON. So I finish putting it back together and put new plugs in while I'm at it. Turn the key, starts right up, runs beautiful and smooth and no more tapping, and the timing is definantly right on.
...fast forward to today 2 days later...
My test pipe and clutch line come in, the last 2 things I needed to get it on the road. So first thing I put the test pipe on. Start my car up to see if I have any exhaust leaks but instead I hear a really random "clank" noise from the engine....so now I'm just like GREAT . BUT the car still runs smooth and doesn't act like anything is wrong.
The best way to explain it is, it sounds like something in the engine banging around. To be sure something didn't come loose inside I took the valve cover off again, visually inspected it saw no marks, or anything inside. Checked the timing again, STILL DEAD ON...then I pull the plugs and #4 is bent down and the electrodes touching like the piston is hitting it or maybe a bent valve:
But here's the thing, that noise isn't constant like the piston is hitting it, it sounds like a different spot all the time hence why I thought something came loose, and it's seriously about 10x louder when you listen from under the engine like it's coming from furhter inside the engine or whatever. So just real quick I put a new plug in it. Start it up, HAPPENS AGAIN
I'm so lost and dumbfounded. Does anyone have any clue what the hell can be causing this or what happened to cause this??? I really hope I'm not ****ed, any and all advice and info would be greatly appreciated.
P.S. sorry for the long *** story and everything, I just wanted it to be very detailed for hopefully better results.
:::EDIT:::
forgot to mention it's a redtop sr in a 95' s14
