icex01x wrote:did this start after you installed the plugs?what type of plugs did you put in?if they were bosch platinums (or +2, or +4) they will cause those symptopms. use only ngk or denso plugs.
I am so sick of hearing how horrible Bosch platinum plugs are. I can't personally vouch for the 2 or 4 prong ones but I have been using the single prong Bosch platinums for over 6 years and 100,00 miles with no problems of any kind what so ever. Maybe I am the only person that these plugs will work for. Or just maybe everyone else has bad karma.
Integrals90: As for the problem of your car it could be a number of small things but I think Gumby has hit it dead on. I doubt it's your pump but I concur that you should check to see if the EGR is engaging at idle, or IACV is sticking. Also if you need to clean your MAF do it with electrical cleaner NOT CARB CLEANER!!
