Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Mon Apr 09, 2007 5:22 am
I don't disagree with Brian's recommendation to check the fuel pressure, but that bounce still sounds like a dead cylinder. Remember that it's possible for an injector to be clogged without being electrically defective. I guess it's possible to have a bad coil pack too, but that's a very rare failure.
If you have a laptop I would absolutely invest in one of the USB Consult boards. We're literally a day or two away from being able to perform a power balance test that will pinpoint the exact cylinder you're having problems with...
The cost of the board and software will probably be about the same as having a dealership run the test for you one time.
Heath
