MeanGreenS13 »
https://forums.nicoclub.com/meangreens13-u31833.html
Tue Dec 27, 2005 2:11 am
Im on the brink of giving up. I have tried everything that i know how to do, to get this thing running correctly. The timing is so weird just to get the car to even be drivable. It POURS out black smoke at idle after you beat on it. The boost leak has been fixed (abuot the only problem i was able to solve) but everything stayed the same. I have a loud whining noise coming out my exhaust before it starts making boost and when it does make boost, its up towards 3500-4000rpm... and even then, it will only hold at 5psi or less. (have stock T25 with 7lb gate on there) it doesnt burn any oil or coolant and the leakdown test came out damn near perfect across the board. i am just lost as to what i should do to get this thing running right. the other thing it does is it breaks up REALLY BAD above 5500 rpm. someone please help
IM DESPRATE!
Phil
Not so MGS13...
