MAJOR HELP NEEDED!!!!! Lug Nut WIll Not Loosen, Possible Cross Threadded!
rico05
Car: 1992 RMS13 w/ CA18DET
I am trying to get off my lug nuts to do my front brakes, and 7 lugs come off like normal. But this last one, loosened, then suddenly grabbed. I think, mabye some dirt on the threads and I try and twist through it. Now it is basically locked and will not come off. I am about 99.99% ready to get rid of this car as every thing I try and fix ends up having 4 others needing attention (last time, it needed new caliper brackets). I had zero problems with my FC so I am thinking of going back to the Mazda....
Nathan
Just keep going at it until it breaks, then replace the lug bolt and nut. You can drive with 3 as long as you dont do anything too ridiculous and fix it pretty quickly.
rico05
Hmmm. I guess I'm no where as strong as I used to be cuz it is STUCK. Can I just change the lug bolt or do I need a new hub and all. Sorry for stupid questions guys, I am still a n00b!
Nathan
Nah, you just have to have the bolt pressed out (I'm certain there is a way to do it yourself with a clamp or something) then you can pull a new one through by tapping it in and then tightening a lug nut down onto it to get it all the way back in. That means you have to get the old one off though ;) I bet the last time those wheels came off the tool that put them back on used an impact wrench, it happens all the time :( This will sound crazy but I've broken lugs loose by planting my foot firmly on one side of a tire iron and pulling up on the other side. If you have a big hollow tube like a metal fence post or something you can make a "cheater" bar too, just slip it over the tire iron.
rico05
Well, now the lug spins freely, but will not come off. Any more ideas?
I was the tool that put them on actually. And I used a tire iron, thank you very much.
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
Try to tighten it back the other way, get a can of PB Blaster and see if you can clean out whatever is in the threads. I't worth a shot. If you keep trying to back it off it's just going to cross the threads more.
Nathan
Hmm, well my apologies for calling you a tool :) I assumed it was the typical idiot with an impact wrench. Grant has a much less destructive way of doing things than I do, might try his way first! If all else fails, cut it off :D
240marcuSX
Car: E34 525i
E46 M3
ive broken several of those @#@$ things, whip out a breaker bar, or a wrench with a long pipe, and you have to be pretty tough with it, but it should come off that way, you can put another one in your self with a hammer, and 2 lug nuts, and an impact. good luck.
i stopped using an impact on mine last time i replaced one of them. ive been using a 4 way lug wrench, and had no problems since.
rico05
It won't tightem. It just spins.
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
SOUNDS LIKE YOU STRIPPED THE NUT AND THE THREADS (IN THAT AREA). TIME FOR THE PICKLE FORK AND HAMMER OR THE CUTOFF WHEEL.
Nathan
Sadly I think project is right...that sucks :( but cutting stuff off is fun too!
Grant@tirerack
The threads must be gone then. How far is it backed off from the wheel? Can you cut off the lugnut without damaging the wheel? I'm thinking a Dremel tool might do the trick. If it comes to that, you can cut out a piece of steel can, flatten it out and tape it over the wheel in case the cutting wheel breaks up or it slips. Good luck!
Nathan
Dremel with a "cut off wheel" the little flexible pen attachment works great too. You sound like your out of options on how to get it off other than cutting.
Grant@tirerack
If you have one, use the fiberglass reinforced type of cutoff wheel. They tend not to break apart in your face as much as the regular ones. Wear saftey glasses when you do this. (Grant, who's trying not to sound too much like a mother hen here :chicken )
rico05
Got it off. Man, the lug and the bolt are JACKED. Where do I get new ones?
Nathan
Grant's right...I cant tell you how many ceramic cut off wheels I've destroyed (actually, about 60, I'm almost through the second pack). The fiberglass ones rock though, I need to pick some up. rico, you can definitely get one at a nissan dealership, but also probably at a pep boys, autozone, etc. We just picked one up for my roommates protege at an autozone so I know they carry them.
Grant@tirerack
I think this thread just set some sort of frequency record for the amount of posts in a given period of time. It's clear that we have a great group of folks here willing to jump in and help at the drop of a hat when one of us is in trouble:jazz:
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
those fiberglass re-enforced disks rule, i got 15 for $12 or something and they last forever.
rico05
So how did I do that? And how do I replace it now that it is busted? Can I get the parts at the Jyard?
