j-z »
https://forums.nicoclub.com/j-z-u11653.html
Tue Aug 15, 2006 11:29 am
yeah its the lower oring thats your problem. same shlt just happened to me recently with my deatschwerks. i first installed them with the lube they came with and had some other problem. the car ran, but would die if i let my foot off the gas (this was from having the iacv nipple before the maf and not after). i installed my stock injectors just to see if it would fix the problem but didnt. checked my plugs and two of them were coated in gas. pulled the dipstick and it reaked of fuel. so i pulled the rail off with the injectors still attatched and fuel lines. turned the key so the pump would come on and the two where the plugs were wet i could see fuel pissing from the injector outlet. i ended up pulling of my injectors and alll of the orings on the bottomrs were torn. this was because when i reinstalled the deatschwekrs after changing out my stock i didnt lube the orings back up. i thought they would be fine just to put in. i noticed they didnt pop in like before when they were lubed. so i got new ones from nissan (both upper and lower) and they had them in stock. this time when i put them on i lubed them up with some motor oil and they poped right in. now after they pop in, spin the injector in the rail a few tims to make sure the orings are properly seated. an easy way to test to make sure all of your work is good is to keep the rail off the intake, with your fuel lines connnected to it still, and turn the key to turn the pump on. make sure you have no leaks and bot the rail back to the mani. make sure you drain that oil with some fresh stuff because i know its full of gas.
