C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Fri Sep 19, 2003 11:17 pm
A blown rod or lost piston would feel like something is way wrong. If the oil pump crapped out, chances are you would have no pressure and get a light on your dash. Check your oil level. If it was at or near the minimum or less, you may have starved the motor for oil during your parking lot antics and spun a rod bearing. The KA24DE does not use hydraulic lifters, so I doubt that will be the problem. I've seen detonation damage pistons which caused a similar noise to a spun bearing, but unless you have a turbo, I doubt this is the problem.
