rb25drag »
https://forums.nicoclub.com/rb25drag-u76935.html
Sun Mar 23, 2008 2:00 pm
Well I finished all my mods Friday, Put the front end back on, was fixing to take a ride when I got in turned the key on and BAM, everything in the car went off. WTF have never had this happen. So i check the fuses and I blew a 30AMP ignition fuse under the hood. So I replace the fuse and hit the switch and it blew the fuse again. So now for the fun part. Tracing wires. Long story short I traced everthing back to a Black/Red wire under the dash that runs all the accessories.
Now for the weird part. I have hooked an alligator clamp to the female end (receiving end) of the 30amp fuse link and I spark it from my solenoid for a 12v source so I can find the problem. Well randomly out of no were everything starts working again!! WTF i have not done anything. So thi has to be a short of some kind under the dash. Well out of no were it goes off again and blows my fuse again just like a power surge, Well I also notice my fuel pump isnt working now either. So I mess around under the dash trying to pull wires, fuses, relays, and everything starts working again!! So while its working I run my volt meter to the fuel pump and im getting 12volts to the pump but it still isnt coming on. So I pull the pump hook a direct 12volts to the pump and it comes on. So I hook my harness back up and it comes on again. WTF?? loose connection? So I put the pump back in the tank and plug it up. Turn the key on and Nothing!!!! We flick the switch a couple times and the pump comes on. So I decide to try and fire the car to see what it does. Half way through the start everything Kills again!!! So now Im back to square 1. I honestly don't know were to look or what to do.
Also We pulled every Fuse/Relay out of the car at once and put power to the ignition and it still sparks my wire BAD!!!
Anyone have anymore Ideas? I have worked for 12 + Hrs this weekend, Ripped half the dash out and fuse panel checking for burnt or discolored wires with No luck.
What I did find is the White wire on the ignition coming from the fuse panel under the hood has some Dis-color as if its been HOT! Which that is the power wire for the Black/red accessory wire. Which leads me to think the black/red wire is at some point pulling too much juice!! But what all does the black/red ignition wire run?
