major distributor cap probs???
tricktunes240
Car: 1992 240sx fastback
THIs is driving me nuts!driving down the road one night slightly aggresivly not to bad though, and during my 2 - 3 shift i miss it and all of a sudden my car stalls out. So i try starting it drivng down the road with my car off at 60 mph....starts breifly then clunks out again. so i pull over and my buddy gets out and pushes on my distributor cap and holds it.....starts like a dream....get home and start it again....nothing...Try putting new distributor cap and disc on and while doing that we pulled out the whole shaft part temporarily and cant get everything lined back up perfectly. So now when i start my car terrible sounds come out such as grinding and wont stay running for more then like 10 seconds at prolby the worst idle ive ever heard. What the heck do i do i figure the timings way off and we tryed taking off the head and allinging the 1st piston TDC and everything but not workin?
anything will help thanx...
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Here's a procedure for setting up the distributor for a DOHC:
First you need to find Top Dead Center (TDC) for the compression stroke in order to time the ignition distributor. To find TDC, remove #1 spark plug and disconnect the ignition coil wire. Have someone tap the ignition switch start position to slowly crank the motor while you put you hand or thumb over the spark plug hole. When you feel the compression, stop. Now look down at the timing pointer at the front pulley. It should be pointing to ZERO. If not, manually turn the motor clockwise or counter-clockwise by hand until it's pointing to ZERO. Now determine the #1 plug wire location on the distributor cap. Mark that location on the distributor body. Now insert the distributor into the block, meshing the gears so that the rotor ends up pointing to the mark you put on the side of the distributor body. You now are timed close to correct; you should be able to start the motor. Before starting the motor, set up a timing light so that you can set the timing to spec. Disconnect the TPS harness connector. It's located on the passenger's side of the engine just above the throttle assembly. Start engine and set timing to 20 degrees BTDC. Check the idle speed. It should read 650 RPM; If not, adjust the idle screw until you get 650 RPM. The idle screw is located on the passenger's side of the engine near the firewall below the intake manifold. Stop the engine. Reconnect the TPS harness connector. Start engine. The idle speed should now be 700 RPM.
