DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Thu Sep 10, 2015 9:07 am
I had the same issue, and frustration.
Basically my solution was to gain access to that direction of the turbo, meaning clearing the stuff towards the front of that side of the engine so I could get a socket wrench with two universals and extensions worked in from the front side and hand-guided to the clamps. Like yours, mine were loose but the ps would not move so I fully loosened the clamp and removed the tubing, reversed the clamp and put back together in an orientation I could service from the rear.
VERY tedious and frustrating work that is common to the Z32 and is characterized by cussing the car, Nissan engineers, and eventually EVERYTHING else, it takes patience and constant breaks to maintain attitude and body function. It took me over three days overall (two weekends) to check and tighten my entire intake tract- one of the toughest jobs I've ever done, but got done correctly and allowed me further testing that produced the necessary results- a bad turbo.
Good Luck!
