korbeano89 wrote:trany fluid and filter, spark plug if needed, there's a zurk fitting to grease up on the drive shaft i think or some where near it, fuel filter, power steering fluid, check distributor cap and rotor, and im sure there's more people will let you know.
If it's a 2001 QX4, then it should have the 3.5 engine. No distributor cap or rotor. Just ignition coils.Agree on the rest though. Spark plugs, fuel filter for sure, if they've never been done.
Mariach wrote:Yea, I just had my front struts and sway bar links replaced, and all fluids changed, belts replaced, filter as well.
How much were the struts? Who did them, dealer or local garage, or DIY?What symptoms were you getting that prompted you to do the struts?I think mine are starting to go, and was wondering what to do about it.
