Eswift »
https://forums.nicoclub.com/eswift-u367.html
Mon Apr 14, 2003 1:01 pm
1st order of business: brakes: if they need it. if not, use permatex silicone vibration dampener on the back of the pads and shims so they dont squeal. or just replace the shims, since they probably werent replaced last time.
youll probably need new struts there, but more important is your timing belt. timing belts on '93s should be replaced every 60k. also water pump, pcv's etc. probably time for new plugs too.
transmission pan drop, filter, full fluid exchange is a good idea, since thats what cripples J30s, if anything.
