Maintenance reminder resets?
Major..Tom
I have a 2011 Pathfinder LE. I use the maintenance reminder screen to remind me of oil changes. It's been randomly clearing my mileage reminder when I shut off the truck. It's random and doesn't happen all the time. A few weeks ago, the radio station presets reverted back to what I assume were factory presets. I've read it can be linked to either the extended storage fuse or the bcm. I checked the extended storage fuse, and it is fine. I pulled the fuse and reseated it; this seems to hold memory for a while but then starts giving me trouble again. Has anyone run into this problem? Any ideas?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
That sounds like corrosion someplace in the fusebox or some other connector. Since popping and reinserting the storage fuse seemed to help, I'd start by yanking that completely and using some contact cleaner on the terminals.
Major..Tom
Thanks VStar for the advice, I'll try that and hope for an easy fix!!
