Larz »
https://forums.nicoclub.com/larz-u216291.html
Mon Jun 10, 2013 6:02 pm
To call that idea a "total scam" is rather harsh, but the problem with alot of peeps who think this way? they're very often right!
If you disregard the advise from the dealer will your power steering unit explode, making your wheels fly off whilst driving at break-neck speeds on the highway? Doubtful. Could the car run forever with the original power steering fluid? Also doubtful.
To my mind, any fluid anywhere on my car must at some point begin to lose the properties and benefits for which it was installed - decreased lubrication, decreased viscosity, etc. I have NOT had my power steering fluid changed, but if you're in doubt - try googling a reliable automotive site that can provide the average lifespan of power steering fluid, recommended change intervals, etc and decide if you're comfortable leaving it unchanged.
As for the brakes, my brake fluid was completely black and felt thick/dirty between my fingers so I had the system flushed and re-filled when the rear brakes were replaced. It was about $100 extra, maybe less and most of that was the cost of the fluid (so I was told).
I would definitely have all the other fluids changed as Ilya recommended - especially if there is no record of it ever being done before you bought the car (assuming you're not the original owner). Otherwise - as bluedevil said - consult the maintenance schedule in your manual.
